Ana içeriğe geç
Makita XPH01 Clutch Leaf Spring Replacement
Neye ihtiyacın var
  1. Makita XPH01 Clutch Leaf Spring Replacement, Battery: adım 1, 1 resimden 1.
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Clutch Leaf Spring Replacement: adım 2, 1 resimden 1.
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Clutch Leaf Spring Replacement: adım 3, 1 resimden 1.
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Clutch Leaf Spring Replacement, Outer Casing: adım 4, 2 resimden 1. Makita XPH01 Clutch Leaf Spring Replacement, Outer Casing: adım 4, 2 resimden 2.
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 Clutch Leaf Spring Replacement: adım 5, 1 resimden 1.
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 Clutch Leaf Spring Replacement: adım 6, 2 resimden 1. Makita XPH01 Clutch Leaf Spring Replacement: adım 6, 2 resimden 2.
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 Clutch Leaf Spring Replacement: adım 7, 2 resimden 1. Makita XPH01 Clutch Leaf Spring Replacement: adım 7, 2 resimden 2.
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 Clutch Leaf Spring Replacement, Clutch Leaf Spring: adım 8, 1 resimden 1.
    • Pull the silver metal clip located towards the back of the motor assembly away from the drill.
  9. Makita XPH01 Clutch Leaf Spring Replacement: adım 9, 2 resimden 1. Makita XPH01 Clutch Leaf Spring Replacement: adım 9, 2 resimden 2.
    • Grip the motor comfortably towards the front of the assembly, and pull it away from the outer casing.
    • The wires are still connected to the back of the motor assembly, so use caution when pulling the motor out. Failing to do this will result in parts falling off the back of the motor.
  10. Makita XPH01 Clutch Leaf Spring Replacement: adım 10, 2 resimden 1. Makita XPH01 Clutch Leaf Spring Replacement: adım 10, 2 resimden 2.
    • Slide the clutch leaf spring off with the spudger.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eric Herwatt
1.020 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 3,113
