Ana içeriğe geç
Makita XPH01 Drill Brush Replacement
Neye ihtiyacın var
  1. Makita XPH01 Drill Brush Replacement, Battery: adım 1, 1 resimden 1.
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Drill Brush Replacement: adım 2, 1 resimden 1.
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Drill Brush Replacement: adım 3, 1 resimden 1.
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Drill Brush Replacement, Drill Brush: adım 4, 1 resimden 1.
    • Hold the drill upright with the back panel facing you.
  5. Makita XPH01 Drill Brush Replacement: adım 5, 2 resimden 1. Makita XPH01 Drill Brush Replacement: adım 5, 2 resimden 2.
    • Unscrew two 18mm screws from the back panel with the Phillips PH2 screwdriver.
  6. Makita XPH01 Drill Brush Replacement: adım 6, 2 resimden 1. Makita XPH01 Drill Brush Replacement: adım 6, 2 resimden 2.
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  7. Makita XPH01 Drill Brush Replacement: adım 7, 3 resimden 1. Makita XPH01 Drill Brush Replacement: adım 7, 3 resimden 2. Makita XPH01 Drill Brush Replacement: adım 7, 3 resimden 3.
    • Hold the drill so the back end is facing toward you.
    • Use the spudger to lift the spring clip out of the back notch.
    • Pull the spring clip forward and rest it in the front notch.
  8. Makita XPH01 Drill Brush Replacement: adım 8, 2 resimden 1. Makita XPH01 Drill Brush Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the tweezers to pull the drill brush away from the sleeve.
  9. Makita XPH01 Drill Brush Replacement: adım 9, 3 resimden 1. Makita XPH01 Drill Brush Replacement: adım 9, 3 resimden 2. Makita XPH01 Drill Brush Replacement: adım 9, 3 resimden 3.
    • Use the plastic opening tool to release the clip connected to the drill brush.
    • Separate the drill brush away from the clip.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Eric Herwatt
1.020 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G4
4 Üyeler
2 Yorum
Mehr Infos gibr’s hier >> https://makita-set.bernaunet.com
joe - Yanıt
You made it very easy. Thank you.
KennyD - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 6,102
