Ana içeriğe geç
Makita XPH01 Forward/Reverse Switch Replacement
Neye ihtiyacın var
    1. Makita XPH01 Forward/Reverse Switch Replacement, Battery: adım 1, 1 resimden 1.
      • Hold the drill upright.
      • Place your finger on the white battery-release button.
      FixBot'a Sor
      Yorum Ekle
    2. Makita XPH01 Forward/Reverse Switch Replacement: adım 2, 1 resimden 1.
      • Press and hold the white release button located on the front of the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Makita XPH01 Forward/Reverse Switch Replacement: adım 3, 1 resimden 1.
      • Slide the battery forward while pressing down on the white battery-release button.
      FixBot'a Sor
      Yorum Ekle
    1. Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: adım 4, 2 resimden 1. Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: adım 4, 2 resimden 2.
      • Hold the drill upright with the back panel facing you.
      • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Makita XPH01 Forward/Reverse Switch Replacement: adım 5, 1 resimden 1.
      • Apply slight pressure to the sides of the backplate and pull away from the drill.
      FixBot'a Sor
      Yorum Ekle
    3. Makita XPH01 Forward/Reverse Switch Replacement: adım 6, 2 resimden 1. Makita XPH01 Forward/Reverse Switch Replacement: adım 6, 2 resimden 2.
      • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Makita XPH01 Forward/Reverse Switch Replacement: adım 7, 2 resimden 1. Makita XPH01 Forward/Reverse Switch Replacement: adım 7, 2 resimden 2.
      • Apply slight pressure to the sides of the outer casing and pull away from the drill.
      FixBot'a Sor
      Yorum Ekle
    1. Makita XPH01 Forward/Reverse Switch Replacement, Forward/Reverse Switch: adım 8, 1 resimden 1.
      • Pull the black trigger assembly away from the drill.
      FixBot'a Sor
      Yorum Ekle
    2. Makita XPH01 Forward/Reverse Switch Replacement: adım 9, 2 resimden 1. Makita XPH01 Forward/Reverse Switch Replacement: adım 9, 2 resimden 2.
      • Grab onto the forward/reverse switch.
      • Gently pull the forward/reverse switch to separate it from the trigger assembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Eric Herwatt
1.038 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G4
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 42
Her zaman: 6,806
