Ana içeriğe geç
Makita XPH01 Forward/Reverse Switch Replacement
Neye ihtiyacın var
  1. Makita XPH01 Forward/Reverse Switch Replacement, Battery: adım 1, 1 resimden 1.
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Forward/Reverse Switch Replacement: adım 2, 1 resimden 1.
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Forward/Reverse Switch Replacement: adım 3, 1 resimden 1.
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: adım 4, 2 resimden 1. Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: adım 4, 2 resimden 2.
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 Forward/Reverse Switch Replacement: adım 5, 1 resimden 1.
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 Forward/Reverse Switch Replacement: adım 6, 2 resimden 1. Makita XPH01 Forward/Reverse Switch Replacement: adım 6, 2 resimden 2.
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 Forward/Reverse Switch Replacement: adım 7, 2 resimden 1. Makita XPH01 Forward/Reverse Switch Replacement: adım 7, 2 resimden 2.
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 Forward/Reverse Switch Replacement, Forward/Reverse Switch: adım 8, 1 resimden 1.
    • Pull the black trigger assembly away from the drill.
  9. Makita XPH01 Forward/Reverse Switch Replacement: adım 9, 2 resimden 1. Makita XPH01 Forward/Reverse Switch Replacement: adım 9, 2 resimden 2.
    • Grab onto the forward/reverse switch.
    • Gently pull the forward/reverse switch to separate it from the trigger assembly.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Eric Herwatt
1.020 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 6,144
