Ana içeriğe geç
Makita XPH01 LED Light Replacement
Neye ihtiyacın var
  1. Makita XPH01 LED Light Replacement, Battery: adım 1, 1 resimden 1.
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 LED Light Replacement: adım 2, 1 resimden 1.
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 LED Light Replacement: adım 3, 1 resimden 1.
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 LED Light Replacement, Outer Casing: adım 4, 2 resimden 1. Makita XPH01 LED Light Replacement, Outer Casing: adım 4, 2 resimden 2.
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 LED Light Replacement: adım 5, 1 resimden 1.
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 LED Light Replacement: adım 6, 2 resimden 1. Makita XPH01 LED Light Replacement: adım 6, 2 resimden 2.
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 LED Light Replacement: adım 7, 2 resimden 1. Makita XPH01 LED Light Replacement: adım 7, 2 resimden 2.
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 LED Light Replacement, LED Light: adım 8, 2 resimden 1. Makita XPH01 LED Light Replacement, LED Light: adım 8, 2 resimden 2.
    • Use the pointed end of a plastic spudger to push the LED out of the drill.
  9. Makita XPH01 LED Light Replacement: adım 9, 2 resimden 1. Makita XPH01 LED Light Replacement: adım 9, 2 resimden 2.
    • Use the pointed edge of a spudger to pull out the black and white wires located on the left hand side of the drill.
    • Use the pointed edge of a spudger to pull out the plastic connector.
  10. Makita XPH01 LED Light Replacement: adım 10, 3 resimden 1. Makita XPH01 LED Light Replacement: adım 10, 3 resimden 2. Makita XPH01 LED Light Replacement: adım 10, 3 resimden 3.
    • Use the flat end of the spudger to push in the clip on the plastic connector.
    • Pull both sides of the plastic connector apart.
  11. Makita XPH01 LED Light Replacement: adım 11, 3 resimden 1. Makita XPH01 LED Light Replacement: adım 11, 3 resimden 2. Makita XPH01 LED Light Replacement: adım 11, 3 resimden 3.
    • Pull the silver metal clip on the motor away from the drill.
  12. Makita XPH01 LED Light Replacement: adım 12, 1 resimden 1.
    • Pull the black trigger assembly away from the drill.
  13. Makita XPH01 LED Light Replacement: adım 13, 2 resimden 1. Makita XPH01 LED Light Replacement: adım 13, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to pull out the LED light assembly.
    very nice tutorial !
    King Rump - Yanıt
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Eric Herwatt
1.020 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G4
4 Üyeler
1Rehber Yorum
Should I do these steps if my drill is under a warranty?
Richard Williams - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 2,801
