Ana içeriğe geç
Mantis Tiller 7566 2017 Carburetor Assembly Replacement
Neye ihtiyacın var
  1. Mantis Tiller 7566 2017 Carburetor Assembly Replacement, Carburetor Assembly: adım 1, 2 resimden 1. Mantis Tiller 7566 2017 Carburetor Assembly Replacement, Carburetor Assembly: adım 1, 2 resimden 2.
    • Remove the air filter cover.
  2. Mantis Tiller 7566 2017 Carburetor Assembly Replacement: adım 2, 2 resimden 1. Mantis Tiller 7566 2017 Carburetor Assembly Replacement: adım 2, 2 resimden 2.
    • Remove two 5/16 standard nuts under the air cover.
    • Remove the last two bolts pictured with a 5/32 Allen wrench.
    • Note the order you remove the bolts. The top is usually longer than the bottom.
  3. Mantis Tiller 7566 2017 Carburetor Assembly Replacement: adım 3, 2 resimden 1. Mantis Tiller 7566 2017 Carburetor Assembly Replacement: adım 3, 2 resimden 2.
    • Remove old carburetor and install the new one. Remove the throttle cable and reinstall with needle nose pliers. Tighten throttle cable to carb part #16100-Z0Z-034
  4. Mantis Tiller 7566 2017 Carburetor Assembly Replacement: adım 4, 1 resimden 1.
    • Reassemble and test throttle.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Trevor A
1.360 İtibar
6 adet Kılavuz yazıldı
2 Yorum
whats the part number
ROGELIO - Yanıt
16100-Z6K-WB3 is the carb i used and worked for a mantis XP tiller.
THOMAS - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 77
Her zaman: 1,872
