Ana içeriğe geç
Manual Top-Cut Can Opener Cutting Wheel Replacement
Neye ihtiyacın var
  1. Manual Top-Cut Can Opener Cutting Wheel Replacement, Cutting Wheel: adım 1, 3 resimden 1. Manual Top-Cut Can Opener Cutting Wheel Replacement, Cutting Wheel: adım 1, 3 resimden 2. Manual Top-Cut Can Opener Cutting Wheel Replacement, Cutting Wheel: adım 1, 3 resimden 3.
    • Remove the 6 mm Phillips screw that secures the cutting wheel.
  2. Manual Top-Cut Can Opener Cutting Wheel Replacement: adım 2, 2 resimden 1. Manual Top-Cut Can Opener Cutting Wheel Replacement: adım 2, 2 resimden 2.
    • Detach the cutting wheel and gear. Place them aside.
  3. Manual Top-Cut Can Opener Cutting Wheel Replacement: adım 3, 1 resimden 1.
    • Liberally spray the WD-40 onto the rusty areas of the shaft.
    • WD-40 is an extremely flammable aerosol. Avoid spraying it near flames, heat, or hot surfaces.
  4. Manual Top-Cut Can Opener Cutting Wheel Replacement: adım 4, 2 resimden 1. Manual Top-Cut Can Opener Cutting Wheel Replacement: adım 4, 2 resimden 2.
    • Scrub the WD-40 and any rust off the can opener using a scouring pad.
    • Wipe away any excess WD-40 with a paper towel.
  5. Manual Top-Cut Can Opener Cutting Wheel Replacement: adım 5, 3 resimden 1. Manual Top-Cut Can Opener Cutting Wheel Replacement: adım 5, 3 resimden 2. Manual Top-Cut Can Opener Cutting Wheel Replacement: adım 5, 3 resimden 3.
    • Reassemble the can opener by reversing steps 1 and 2 with a new wheel:
    • Place the gear and new cutting wheel onto the shaft.
    • Reinsert the 6 mm Phillips screw and fasten it in place.
Sonuç
Once reassembly is complete, your can opener will be as good as new!
Hannah Freitas
133 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 3-2, Whithaus Spring 2025 UC Davis, Team 3-2, Whithaus Spring 2025 üyesi
UCD-WHITHAUS-S25S3G2
3 Üyeler
1 Kılavuz yazıldı
1Rehber Yorum
Onde acho uma nova roda ou novo disco para comprar?
NEWTON SANTOS PEREIRA - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 73
Her zaman: 439
