Ana içeriğe geç
Maquet Servo-U Expiratory Cassette Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
  1. Maquet Servo-U Expiratory Cassette Replacement, Expiratory Cassette: adım 1, 1 resimden 1.
    • Orient the ventilator so the upgrade slots (front) are facing away from you and that you are looking at the back of the device.
    • Switch off the ventilator system using the on/off switch on the patient unit, which is located on on the lower half of the unit behind a white door panel.
    • Disconnect the ventilator system from the mains power and gas supply.
  2. Maquet Servo-U Expiratory Cassette Replacement: adım 2, 1 resimden 1.
    • In the following order:
    • Press the button on the expiratory cassette.
    • Tilt the cassette upwards and remove.
    • The expiratory cassette is a precision instrument and must be handled carefully.
  3. Maquet Servo-U Expiratory Cassette Replacement: adım 3, 1 resimden 1.
    • Hinge the expiratory cassette and press it firmly down into lock position.
    • Make sure that the cassette clicks into position. Check that it cannot be moved upwards and that the button on top of the cassette is completely ejected.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Cassandra Aarrestad
627 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G2, Paton Spring 2020 Cal Poly, Team S7-G2, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 14
Son 30 gün: 58
Her zaman: 2,980
