Giriş
This guide will show you how to replace cracked, damaged, or malfunctioning spray bars on your Emperor 400. For simplicity, the guide uses pictures with the media filters and Bio-Wheels removed (These simply slide upward out of the device once the cover is removed). The filter is also not attached to an aquarium in this guide, however, this can all be done while the filter is still hanging on the back of your aquarium (unplugged).
Neye ihtiyacın var
First thing's first, unplug the device to avoid any unnecessary water spillage.
Remove the Flow Manifold Housing Cover to gain access to the components of the Emperor 400. Simply lift up on the cover.
The spray bars are located above the Bio-Wheels. They are horizontal cross bars with small holes for water to pass through.
Remove the safety clip(s). They are gray rings (the only non-black part of the outside shell) located on the outer ends of the spray bars. This will allow you to remove the spray bar(s), and assures that when the device is functioning, there will be no water leakage.
Slide the damaged/broken spray bar(s) outward from the center of the device. This needs to be done one at a time.
A little extra force will have to be provided in order to pop the O-rings through the device's shell.
Insert the new, functional spray bar(s) one at a time through the openings for the bars on either side of the device.
Slide the bar(s) all the way through to the other opening located in the middle of the device.
Be sure when the spray bars are inserted that the holes in the bars are angled downwards. The ends of the spray bars have grooves to show that you are pointing them in the correct direction.
With the new spray bar(s) installed, the Flow Manifold Housing Cover can be put back on, and the device (with correct water level in it) can be plugged back in which will power it on automatically.
Follow these instructions for dis-assembly and re-assembly of the spray bars on your Emperor 400.
2 farklı kişi bu kılavuzu tamamladı.
