Giriş
Are the buttons and switches on the top panel of your Marshall Woburn not responding? If so, here is the guide on how to take out the top control panel. All you need is the standard #1 Phillips Screwdriver head to remove the screws involved with this replacement.
Neye ihtiyacın var
On a flat surface, orient the device so that the front grille is facing downward.
Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
Using a Philips #1 screwdriver, remove the eight 9.5 mm screws that are marked in red from the perimeter of the metal frame for the top control panel.
From the outside of the speaker, push down on the top control panel until you can feel the adhesive holding it to the frame start to loosen.
On the inside, make your way around the border of the top control panel and remove the adhesive until you can fully remove the panel from the frame.
