Ana içeriğe geç
Marshall Emberton Button Replacement
Neye ihtiyacın var
  1. Marshall Emberton Button Replacement, Button: adım 1, 1 resimden 1.
    • Remove the rubber casing from the speaker by peeling it off using your nails.
    FixBot'a Sor
    Yorum Ekle
  2. Marshall Emberton Button Replacement: adım 2, 1 resimden 1.
    • Use a TR9 screwdriver to remove the eight 1 cm screws located on top of the speaker.
    FixBot'a Sor
    Yorum Ekle
  3. Marshall Emberton Button Replacement: adım 3, 1 resimden 1.
    • Once all the screws are off, you must pry the plastic piece off using any tool capable of sliding into the crevice. Then easily pop the piece out.
    FixBot'a Sor
    Yorum Ekle
  4. Marshall Emberton Button Replacement: adım 4, 1 resimden 1.
    • On the back side of the plastic piece, there is a circuit which is shown in the picture. Use a TR9 screwdriver to remove two 1.2 cm screws to detach the circuit from the plastic housing.
    FixBot'a Sor
    Yorum Ekle
  5. Marshall Emberton Button Replacement: adım 5, 1 resimden 1.
    • Once the circuit is removed, you may gently pop the button off and easily replace it with a new one.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Asia Baldwin
781 İtibar
5 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-1, Adachi Fall 2022 CSU Los Angeles, Team 5-1, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S5G1
5 Üyeler
7 adet Kılavuz yazıldı
4Kılavuz Yorumları
where can i find a replacement button
MANU 1907 - Yanıt Paylaş
The worst instruction I've ever seen in my life. If you do this, you will break your device.
cool eo - Yanıt Paylaş
yes, i confirme !!!
Mallet Jp - Yanıt Paylaş
@cooleo fortunately i figured it out but yeah you ned to disassemble multiple parts. disassemble from the front panel (marshal logo panel is pressure fit, undo the phillips, and take the board out behind it, and then take out the top out + switch.
Daniel Hyunsu Kim - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 23
Son 30 gün: 201
Her zaman: 4,416
