Ana içeriğe geç
Marshall Emberton Main Speaker Replacement
Neye ihtiyacın var
  1. Marshall Emberton Main Speaker Replacement, Main Speaker: adım 1, 1 resimden 1.
    • Remove the rubber casing from the speaker by peeling it off using your nails.
  2. Marshall Emberton Main Speaker Replacement: adım 2, 1 resimden 1.
    • Pry the front of the speaker that says "Marshall" in order to get inside the speaker.
  3. Marshall Emberton Main Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the eight 1.2 cm screws using a TR9 screwdriver.
  4. Marshall Emberton Main Speaker Replacement: adım 4, 1 resimden 1.
    • Now pop the speaker out and remove the entire piece.
  5. Marshall Emberton Main Speaker Replacement: adım 5, 1 resimden 1.
    • Now you must disconnect two wire connectors, by firmly tugging on the wires.
    • The new speakers can now be connected and put back together.
Sonuç
Asia Baldwin
697 İtibar
5 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-1, Adachi Fall 2022 CSU Los Angeles, Team 5-1, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S5G1
5 Üyeler
Bir Yorum
Hi! Where from can I by the speakers? pls help
Cristian MUNTEANU - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 24
Son 30 gün: 103
Her zaman: 2,505
