Giriş
If you are hearing popping sounds when high pitch sounds are played then there could be a problem with your tweeters and they need to be replaced. This guide will teach you how to do just that.
Neye ihtiyacın var
Place the unit face down as shown in the picture, exposing the battery cover.
Remove the two 4.0mm long screws holding the cover on using a T10 driver.
Place speaker as shown in image and remove the four corner 45.5mm back cover screws with a Phillips #2 driver.
Using a Phillips #2 driver, remove the six remaining 21.5mm outer back cover screws.
Remove the back cover by using the vent hole as a grip.
Gently pull out the back cover and let it hang on the side of the speaker that has the knobs and power switch.
Unplug the main power lead from the control board; this allows the back to be opened more, allowing easy access to the power switch.
Unscrew the eight 22.5mm screws of the speaker cover and the device using a Phillips #2 screwdriver.
Gently push the speaker cover out of the stereo speaker.
Remove the four 13.5mm screws that are placed on the tweeters with a Phillips #2 screwdriver.
2 farklı kişi bu kılavuzu tamamladı.
