Ana içeriğe geç
Marshall Stanmore II Power Switch Replacement
Neye ihtiyacın var
  1. Marshall Stanmore II Power Switch Replacement, Rear Panel: adım 1, 2 resimden 1. Marshall Stanmore II Power Switch Replacement, Rear Panel: adım 1, 2 resimden 2.
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
    FixBot'a Sor
    Yorum Ekle
  2. Marshall Stanmore II Power Switch Replacement: adım 2, 2 resimden 1. Marshall Stanmore II Power Switch Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
    FixBot'a Sor
    Yorum Ekle
  3. Marshall Stanmore II Power Switch Replacement: adım 3, 2 resimden 1. Marshall Stanmore II Power Switch Replacement: adım 3, 2 resimden 2.
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
    FixBot'a Sor
    Yorum Ekle
  4. Marshall Stanmore II Power Switch Replacement, Power Switch: adım 4, 3 resimden 1. Marshall Stanmore II Power Switch Replacement, Power Switch: adım 4, 3 resimden 2. Marshall Stanmore II Power Switch Replacement, Power Switch: adım 4, 3 resimden 3.
    • Locate the Power Switch PCB on the left-hand side above the subwoofer.
    • Use a Phillips #2 screwdriver to remove the two 10 mm screws that secure the PCB.
    • Because the space inside is somewhat cramped, consider using the iFixit 150 mm Flex Extension included in the iFixit Pro Tech Toolkit.
    FixBot'a Sor
    Yorum Ekle
  5. Marshall Stanmore II Power Switch Replacement: adım 5, 2 resimden 1. Marshall Stanmore II Power Switch Replacement: adım 5, 2 resimden 2.
    • Locate the PCB's black wire connector and gently disconnect it.
    • Do not pull on the wires.
    FixBot'a Sor
    Yorum Ekle
  6. Marshall Stanmore II Power Switch Replacement: adım 6, 3 resimden 1. Marshall Stanmore II Power Switch Replacement: adım 6, 3 resimden 2. Marshall Stanmore II Power Switch Replacement: adım 6, 3 resimden 3.
    • Pull the PCB out of the mount.
    • Take care not to damage the rubber seal surrounding the switch base as depicted in picture two.
    • Rocking the PCB back and forth while pulling may help remove the module.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Hellooooo very good but were did you fint the eplace the power switch ?
Fred - Yanıt Paylaş
Where can buy on /off switch ?
Choi Kee - Yanıt Paylaş
On/off switch bar is broken
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 33
Son 30 gün: 114
Her zaman: 2,879
