Ana içeriğe geç
Marshall Stanmore II Subwoofer Assembly Replacement
Neye ihtiyacın var
  1. Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: adım 1, 2 resimden 1. Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: adım 1, 2 resimden 2.
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
    FixBot'a Sor
    Yorum Ekle
  2. Marshall Stanmore II Subwoofer Assembly Replacement: adım 2, 2 resimden 1. Marshall Stanmore II Subwoofer Assembly Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
    FixBot'a Sor
    Yorum Ekle
  3. Marshall Stanmore II Subwoofer Assembly Replacement: adım 3, 2 resimden 1. Marshall Stanmore II Subwoofer Assembly Replacement: adım 3, 2 resimden 2.
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
    FixBot'a Sor
    Yorum Ekle
  4. Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: adım 4, 3 resimden 1. Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: adım 4, 3 resimden 2. Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: adım 4, 3 resimden 3.
    • Pull back the clear sheaths on the end of each wire to expose the terminals.
    • Using a pair of tweezers, or your fingernail, depress the small latch and gently pull the wire off of the metal tabs.
    • Failure to press the latch while pulling could damage the subwoofer and/or wires.
    FixBot'a Sor
    Yorum Ekle
  5. Marshall Stanmore II Subwoofer Assembly Replacement: adım 5, 1 resimden 1.
    • Remove the six 20.5 mm T20 Torx screws that secure the subwoofer to the housing.
    • The subwoofer assembly contains a very strong magnet, so the screwdriver and screws may occasionally stick to the side of the assembly.
    FixBot'a Sor
    Yorum Ekle
  6. Marshall Stanmore II Subwoofer Assembly Replacement: adım 6, 1 resimden 1.
    • Carefully lift the subwoofer assembly away from the housing.
    FixBot'a Sor
    Yorum Ekle
  7. Marshall Stanmore II Subwoofer Assembly Replacement: adım 7, 1 resimden 1.
    • Optional: Inspect the felt gasket on the speaker frame for any tears or foreign material.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 63
Her zaman: 1,331
