Ana içeriğe geç
Marshall Stanmore II Tweeter Assembly Replacement
Neye ihtiyacın var
  1. Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: adım 1, 2 resimden 1. Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: adım 1, 2 resimden 2.
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
    FixBot'a Sor
    Yorum Ekle
  2. Marshall Stanmore II Tweeter Assembly Replacement: adım 2, 2 resimden 1. Marshall Stanmore II Tweeter Assembly Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
    FixBot'a Sor
    Yorum Ekle
  3. Marshall Stanmore II Tweeter Assembly Replacement: adım 3, 2 resimden 1. Marshall Stanmore II Tweeter Assembly Replacement: adım 3, 2 resimden 2.
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
    FixBot'a Sor
    Yorum Ekle
  4. Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: adım 4, 2 resimden 1. Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: adım 4, 2 resimden 2.
    • Carefully pull back the translucent plastic sheathing on the two silver tweeter connectors.
    FixBot'a Sor
    Yorum Ekle
  5. Marshall Stanmore II Tweeter Assembly Replacement: adım 5, 3 resimden 1. Marshall Stanmore II Tweeter Assembly Replacement: adım 5, 3 resimden 2. Marshall Stanmore II Tweeter Assembly Replacement: adım 5, 3 resimden 3.
    • Using your fingernail or tweezers, apply precise pressure to the small latch in the middle of the connector and gently pull upwards to disconnect the connector.
    • Repeat for the second connector.
    FixBot'a Sor
    Yorum Ekle
  6. Marshall Stanmore II Tweeter Assembly Replacement: adım 6, 2 resimden 1. Marshall Stanmore II Tweeter Assembly Replacement: adım 6, 2 resimden 2.
    • Use a Torx T20 screwdriver to remove the three 20.5 mm screws that secure the tweeter.
    • Lift the tweeter assembly from its housing.
    FixBot'a Sor
    Yorum Ekle
  7. Marshall Stanmore II Tweeter Assembly Replacement: adım 7, 1 resimden 1.
    • The felt seal is removable. If there is no seal on the tweeter, it may be stuck to the cutout on the speaker frame.
    • Repeat steps 4-6 to remove the second tweeter if necessary.
    FixBot'a Sor
    Yorum Ekle
Sonuç
1Rehber Yorum
Do you know the tweeter spec? Or similar brand to install?
Leonardo Hernández - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 42
Her zaman: 799
