Ana içeriğe geç
Marshall Woburn Tweeter Replacement
Neye ihtiyacın var
  1. Marshall Woburn Tweeter Replacement, Back Panel: adım 1, 2 resimden 1. Marshall Woburn Tweeter Replacement, Back Panel: adım 1, 2 resimden 2.
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Marshall Woburn Tweeter Replacement: adım 2, 2 resimden 1. Marshall Woburn Tweeter Replacement: adım 2, 2 resimden 2.
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
    FixBot'a Sor
    Yorum Ekle
  3. Marshall Woburn Tweeter Replacement: adım 3, 1 resimden 1.
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
    FixBot'a Sor
    Yorum Ekle
  4. Marshall Woburn Tweeter Replacement, I/O Board: adım 4, 1 resimden 1.
    • Disconnect the 5 wires circled in red from the back input board.
    • Grip and pull the connectors, not the wires.
    • There may be a little resistance when pulling on the connectors, but it should not require excessive force.
    FixBot'a Sor
    Yorum Ekle
  5. Marshall Woburn Tweeter Replacement: adım 5, 2 resimden 1. Marshall Woburn Tweeter Replacement: adım 5, 2 resimden 2.
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
    FixBot'a Sor
    Yorum Ekle
  6. Marshall Woburn Tweeter Replacement: adım 6, 1 resimden 1.
    • Completely remove the I/O board and the attached plate.
    FixBot'a Sor
    Yorum Ekle
  7. Marshall Woburn Tweeter Replacement, Tweeter: adım 7, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the eight 15.8 mm screws attaching the tweeters to the frame.
    • Disconnect the two wires from the back of each tweeter.
    FixBot'a Sor
    Yorum Ekle
  8. Marshall Woburn Tweeter Replacement: adım 8, 1 resimden 1.
    • Lift the tweeter from the frame to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Kenneth
174 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 üyesi
UMASSD-GULBRANDSEN-F23S2G4
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Any ideas to which new tweeters to buy?
Lars - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 34
Her zaman: 986
