Ana içeriğe geç
Martian Victory Lithium Battery Replacement
Neye ihtiyacın var
  1. Martian Victory Lithium Battery Replacement, Back Plate: adım 1, 2 resimden 1. Martian Victory Lithium Battery Replacement, Back Plate: adım 1, 2 resimden 2.
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory Lithium Battery Replacement: adım 2, 1 resimden 1.
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory Lithium Battery Replacement, Lithium Battery: adım 3, 1 resimden 1.
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory Lithium Battery Replacement: adım 4, 1 resimden 1.
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
Sonuç
Bir başkası bu kılavuzu tamamladı.
David Miller
246 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Baechle Fall 2016 IUPUI, Team 3-3, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S3G3
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
I’m wondering… where did you buy the replacement battery?
Randy Trask - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 829
