Ana içeriğe geç
Martian Victory Watch band Replacement
Neye ihtiyacın var
  1. Martian Victory Watch band Replacement, Watch band: adım 1, 1 resimden 1.
    • Take the watch band removal tool and insert it in the small slit between watch bezel and the band, resting up against the bezel.
  2. Martian Victory Watch band Replacement: adım 2, 1 resimden 1.
    • Press down of the shaft that holds the band on, while simultaneously dragging the tip of the tool back towards the band in order to compress the spring bar that holds the band on.
    • Drag the tip of the tool away from the bezel while still pressing down in order to remove the shaft from the bezel.
    • The spring shaft may decompress once its out of the bezel and try to shoot away.
  3. Martian Victory Watch band Replacement: adım 3, 1 resimden 1.
    • Repeat these steps on the other side of the band to completely remove the band, ready for cleaning or replacement.
Sonuç
Dominic Coffey
231 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Baechle Fall 2016 IUPUI, Team 3-3, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S3G3
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 271
