Ana içeriğe geç
MasterCraft Eliminator Waterproof Spotlight Battery Replacement
Neye ihtiyacın var
  1. MasterCraft Eliminator Waterproof Spotlight Battery Replacement, Battery: adım 1, 2 resimden 1. MasterCraft Eliminator Waterproof Spotlight Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Twist the front cover of the spotlight in a counter-clockwise rotation and remove it from the device.
  2. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: adım 2, 2 resimden 1. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: adım 2, 2 resimden 2.
    • Remove the rear piece which is the protection cover for the charging port.
  3. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: adım 3, 2 resimden 1. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: adım 3, 2 resimden 2.
    • Using the JIS #00 screwdriver, remove the two screws securing the motherboard to the device.
  4. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: adım 4, 3 resimden 1. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: adım 4, 3 resimden 2. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: adım 4, 3 resimden 3.
    • Using the JIS #00 screwdriver, remove the single screw securing the charging port and remove the charging port from the device.
  5. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: adım 5, 3 resimden 1. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: adım 5, 3 resimden 2. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: adım 5, 3 resimden 3.
    • Carefully disconnect the battery and remove it from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Can you get the 3wledbulb
olddoc55 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 47
Her zaman: 1,587
