Ana içeriğe geç
Matsunichi M97 9 inch Battery Replacement
Neye ihtiyacın var
  1. Matsunichi M97 9 inch Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Open the micro SD cover located on the back of the device.
  2. Matsunichi M97 9 inch Battery Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the two 4mm screws next to the micro SD port.
  3. Matsunichi M97 9 inch Battery Replacement: adım 3, 3 resimden 1. Matsunichi M97 9 inch Battery Replacement: adım 3, 3 resimden 2. Matsunichi M97 9 inch Battery Replacement: adım 3, 3 resimden 3.
    • Use the iFixit opening tool to pry off the back cover of the device.
    • The volume buttons and the lock switch will come loose when the back comes off.
  4. Matsunichi M97 9 inch Battery Replacement: adım 4, 2 resimden 1. Matsunichi M97 9 inch Battery Replacement: adım 4, 2 resimden 2.
    • Use a pair of tweezers to disconnect the battery from the motherboard.
  5. Matsunichi M97 9 inch Battery Replacement: adım 5, 2 resimden 1. Matsunichi M97 9 inch Battery Replacement: adım 5, 2 resimden 2.
    • Carefully unstick the battery from the frame using the spudger.
    • Do not bend or puncture the battery during removal.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 10
Her zaman: 354
