Ana içeriğe geç
Matsunichi M97 9 inch Screen Replacement
Neye ihtiyacın var
  1. Matsunichi M97 9 inch Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Open the micro SD cover located on the back of the device.
  2. Matsunichi M97 9 inch Screen Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the two 4mm screws next to the micro SD port.
  3. Matsunichi M97 9 inch Screen Replacement: adım 3, 3 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 3, 3 resimden 2. Matsunichi M97 9 inch Screen Replacement: adım 3, 3 resimden 3.
    • Use the iFixit opening tool to pry off the back cover of the device.
    • The volume buttons and the lock switch will come loose when the back comes off.
  4. Matsunichi M97 9 inch Screen Replacement: adım 4, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 4, 2 resimden 2.
    • Use a pair of tweezers to disconnect the battery from the motherboard.
  5. Matsunichi M97 9 inch Screen Replacement: adım 5, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 5, 2 resimden 2.
    • Carefully unstick the battery from the frame using the spudger.
    • Do not bend or puncture the battery during removal.
  6. Matsunichi M97 9 inch Screen Replacement, Motherboard: adım 6, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement, Motherboard: adım 6, 2 resimden 2.
    • Remove the six 2mm screws that hold the motherboard onto the case using the Phillips #00 screwdriver.
    • Use the same screwdriver to remove the single 4mm screw.
  7. Matsunichi M97 9 inch Screen Replacement: adım 7, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 7, 2 resimden 2.
    • Gently pull the display ribbon cable to unplug it from the motherboard.
  8. Matsunichi M97 9 inch Screen Replacement: adım 8, 1 resimden 1.
    • Use a spudger or an iFixit opening tool to lift the locking mechanism holding the camera ribbon cable.
  9. Matsunichi M97 9 inch Screen Replacement: adım 9, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 9, 2 resimden 2.
    • Lift up on the wifi antenna cable to unsnap it from the motherboard.
    • Then unhook the cable from the holding bracket.
  10. Matsunichi M97 9 inch Screen Replacement: adım 10, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 10, 2 resimden 2.
    • Use the spudger or iFixit opening tool to lift up on the locking mechanism for the digitizer ribbon cable.
    • Pull the cable from its connection.
  11. Matsunichi M97 9 inch Screen Replacement: adım 11, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 11, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the four 4mm screws that hold the speakers in place.
  12. Matsunichi M97 9 inch Screen Replacement: adım 12, 1 resimden 1.
    • Pull the vibration motor out of its housing.
  13. Matsunichi M97 9 inch Screen Replacement: adım 13, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 13, 2 resimden 2.
    • Lift the motherboard off the frame.
  14. Matsunichi M97 9 inch Screen Replacement, Camera: adım 14, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement, Camera: adım 14, 2 resimden 2.
    • Remove the camera from the device.
  15. Matsunichi M97 9 inch Screen Replacement, Screen: adım 15, 3 resimden 1. Matsunichi M97 9 inch Screen Replacement, Screen: adım 15, 3 resimden 2. Matsunichi M97 9 inch Screen Replacement, Screen: adım 15, 3 resimden 3.
    • Peel off the black and the clear tape covering the display cable connection.
    • Pull the display cable to disconnect it from the display.
  16. Matsunichi M97 9 inch Screen Replacement: adım 16, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 16, 2 resimden 2.
    • Peel off the conductive tape covering the display board.
  17. Matsunichi M97 9 inch Screen Replacement: adım 17, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 17, 2 resimden 2.
    • Peel off the Kapton thermal tape from the display board.
  18. Matsunichi M97 9 inch Screen Replacement: adım 18, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 18, 2 resimden 2.
    • Peel off the grounding tape attached to the display board.
  19. Matsunichi M97 9 inch Screen Replacement: adım 19, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 19, 2 resimden 2.
    • Peel off the black tape near the wifi antenna from the frame.
    • Do not pull the tape completely off to avoid damage to the wifi antenna.
  20. Matsunichi M97 9 inch Screen Replacement: adım 20, 2 resimden 1. Matsunichi M97 9 inch Screen Replacement: adım 20, 2 resimden 2.
    • Using the Phillips #00 screwdriver, unscrew the seven 4mm screws holding the frame to the front glass.
    • Gently lift the frame off the LCD panel
  21. Matsunichi M97 9 inch Screen Replacement: adım 21, 1 resimden 1.
    • Lift up the LCD panel from the glass digitizer.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 96
