Ana içeriğe geç
Matsunichi MarquisPad MP977 Front Facing Camera Replacement
Neye ihtiyacın var
  1. Matsunichi MarquisPad MP977 Front Facing Camera Replacement, Front Facing Camera: adım 1, 1 resimden 1.
    • Using the PH #00 Phillips head screwdriver, unscrew the two screws.
  2. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: adım 2, 3 resimden 1. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: adım 2, 3 resimden 2. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: adım 2, 3 resimden 3.
    • Place the device face down on a flat surface.
    • Insert the wide-tipped plastic opening tool into the top of the left speaker slot.
    • Be sure not to puncture the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and the back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: adım 3, 2 resimden 1. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: adım 3, 2 resimden 2.
    • Insert the opening tool into the slot located to the right of the speaker, at the top edge of the device.
    • Then, pry open the back plate of the device , and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: adım 4, 1 resimden 1.
    • Remove the back plate and place it to the side of the device.
  5. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: adım 5, 1 resimden 1.
    • With the same screw driver, PH #00 Phillips head, remove the seven screws holding in the motherboard.
    • Place the screws somewhere safe where they wont fall.
  6. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: adım 6, 2 resimden 1. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: adım 6, 2 resimden 2.
    • Gently pull the camera optic fiber out of it's slot to release the flap. This will allow the flap to open easily.
    • Be sure not to damage the camera port.
  7. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: adım 7, 2 resimden 1. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: adım 7, 2 resimden 2.
    • Last, Insert the new camera into the pinhole camera slot.
Sonuç
Kathryn Sherlock
127 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 üyesi
UMASSD-VIJAYBHASKAR-S15S4G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 221
