Ana içeriğe geç
Matsunichi MarquisPad MP977 Plastic Front Panel Replacement
Neye ihtiyacın var
  1. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement, Plastic Front Panel: adım 1, 1 resimden 1.
    • Remove the two screws using a PH #00 Phillips head screw driver.
  2. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: adım 2, 3 resimden 1. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: adım 2, 3 resimden 2. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: adım 2, 3 resimden 3.
    • Place the device face down on a flat surface.
    • Insert one of the wide tipped, plastic opening tools into the top of the left speaker slot.
    • Be sure not to puncture the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: adım 3, 2 resimden 1. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: adım 3, 2 resimden 2.
    • Insert opening tool into the right speaker slot.
    • Pry open the back plate, and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: adım 4, 1 resimden 1.
    • Remove the back plate and place it to the side.
  5. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: adım 5, 1 resimden 1.
    • Remove the screws holding the metal frame plate in place.
    • Remove the metal frame plate from the plastic housing.
  6. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: adım 6, 2 resimden 1. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: adım 6, 2 resimden 2.
    • Place the metal frame plate and components into the new plastic front panel.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rachel Servis
89 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 üyesi
UMASSD-VIJAYBHASKAR-S15S4G1
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
where can you order the front plastic panel from? and how much?
daf01ca - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 366
