Ana içeriğe geç
Mavic 2 Camera/Gimbal Unit Replacement
Neye ihtiyacın var
  1. Mavic 2 Camera/Gimbal Unit Replacement, Camera/Gimbal Unit: adım 1, 1 resimden 1.
    • Remove the two 2x5 mm screws from the plastic piece near the camera on bottom side using the Allen key.
  2. Mavic 2 Camera/Gimbal Unit Replacement: adım 2, 1 resimden 1.
    • Remove plastic part from previous step.
  3. Mavic 2 Camera/Gimbal Unit Replacement: adım 3, 1 resimden 1.
    • Remove ribbon cable connecting to camera by pulling at camera connection point.
  4. Mavic 2 Camera/Gimbal Unit Replacement: adım 4, 1 resimden 1.
    • Unscrew 1.5 x 4.5 mm gimbal mount screw using Allen key.
  5. Mavic 2 Camera/Gimbal Unit Replacement: adım 5, 1 resimden 1.
    • Use Allen key to remove screws holding nose plate, in the front left and right corners in front of the camera.
  6. Mavic 2 Camera/Gimbal Unit Replacement: adım 6, 1 resimden 1.
    • Pull camera and gimbal from drone.
  7. Mavic 2 Camera/Gimbal Unit Replacement: adım 7, 1 resimden 1.
    • Remove four rubber parts from camera mount.
  8. Mavic 2 Camera/Gimbal Unit Replacement: adım 8, 1 resimden 1.
    • Remove camera from frame by pulling apart.
Sonuç
ColynOB
172 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Harley Fall 2023 IUPUI, Team 2-3, Harley Fall 2023 üyesi
IUPUI-HARLEY-F23S2G3
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 55
Her zaman: 648
