Ana içeriğe geç
Mavic 2 Controller Joystick Replacement
Neye ihtiyacın var
  1. Mavic 2 Controller Joystick Replacement, Controller Joystick: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the two 5.7 mm screws from the bottom of the controller.
  2. Mavic 2 Controller Joystick Replacement: adım 2, 2 resimden 1. Mavic 2 Controller Joystick Replacement: adım 2, 2 resimden 2.
    • Insert the opening tool to separate the small plastic part from the main housing of the controller that was unscrewed in the last part.
    • Remove the remaining plastic cover by unclipping the tabs located next to the charging port. Detach the clips that are below the screen that are holding the plastic part in place.
    • Now you should be able to pull out the bottom cover piece.
  3. Mavic 2 Controller Joystick Replacement: adım 3, 3 resimden 1. Mavic 2 Controller Joystick Replacement: adım 3, 3 resimden 2. Mavic 2 Controller Joystick Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a Phillips #0 screwdriver to remove the two 5.7 mm screws that are secure the top cover.
    • Remove the cable connecting the joystick to the board with a pair of tweezers.
    • There is a cable on both sides, so get both.
    • Go around the top cover, undoing all clips holding the top cover on. Insert the opening tool in between the top cover and the lower base of the controller.
  4. Mavic 2 Controller Joystick Replacement: adım 4, 2 resimden 1. Mavic 2 Controller Joystick Replacement: adım 4, 2 resimden 2.
    • Now that the top cover is removed flip it over and you will see something similar to picture one.
    • You will need to use the Phillip #0 to remove the four screws holding the joystick to the top cover plate.
    • This will allow you to replace the joystick with a new one.
Sonuç
Quentin Rodriguez
115 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Harley Fall 2023 IUPUI, Team 2-3, Harley Fall 2023 üyesi
IUPUI-HARLEY-F23S2G3
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 276
