Ana içeriğe geç
Mavic 2 Main Board Replacement
Neye ihtiyacın var
  1. Mavic 2 Main Board  Replacement, Remove screws: adım 1, 1 resimden 1.
    • Begin to remove screws from belly of drone.
  2. Mavic 2 Main Board  Replacement, Continue to remove screws: adım 2, 3 resimden 1. Mavic 2 Main Board  Replacement, Continue to remove screws: adım 2, 3 resimden 2. Mavic 2 Main Board  Replacement, Continue to remove screws: adım 2, 3 resimden 3.
    • remove the rest of the screws
  3. Mavic 2 Main Board  Replacement: adım 3, 2 resimden 1. Mavic 2 Main Board  Replacement: adım 3, 2 resimden 2.
    • After all 8 Screws are removed. Remove the back panel. Keep in mind there is a ribbon connecting the panel and the main board. You must detach the ribbon from either side.
  4. Mavic 2 Main Board  Replacement: adım 4, 1 resimden 1.
    • Unscrew the screws holding the board in place, as well as all the ribbons and antennas connecting the board to the frame.
  5. Mavic 2 Main Board  Replacement: adım 5, 1 resimden 1.
    • Then remove the old board. Replace the new board you have and repeat the process in reverse.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Hello sir,
I have a question and I hope to find the answer
The plane (Mavic 2) collided with a pilot turned into a pole, and after that, I find a stutter in the camera from time to time, so I hope to find a way to solve this problem since the camera works, the camera shake.
Amr Ahmed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 32
Her zaman: 1,467
