Ana içeriğe geç
MaxWest TAB-7360DC Motherboard Replacement
Neye ihtiyacın var
  1. MaxWest TAB-7360DC Motherboard Replacement, Back Hard Case: adım 1, 3 resimden 1. MaxWest TAB-7360DC Motherboard Replacement, Back Hard Case: adım 1, 3 resimden 2. MaxWest TAB-7360DC Motherboard Replacement, Back Hard Case: adım 1, 3 resimden 3.
    • Insert plastic opening tool at the corner of the screen, in between the back case and the front.
    • Volume buttons will fall out during removal.
    • When opening up the case, have the I/O ports facing you and turn the back case towards the right. There is a short wire connecting the speaker to the logic board.
  2. MaxWest TAB-7360DC Motherboard Replacement: adım 2, 2 resimden 1. MaxWest TAB-7360DC Motherboard Replacement: adım 2, 2 resimden 2.
    • Carefully pry the tape from the battery, the bottom left chip, and the ribbon cable towards the bottom-right of the board. The bottom left has a little silver square component that must also be unclipped and untaped.
    • The battery is glued to the back of the screen; therefore pull the battery off of the back with caution. There will be resistance but that's okay.
  3. MaxWest TAB-7360DC Motherboard Replacement: adım 3, 1 resimden 1.
    • Gently unclip the data cable retainers and remove the wires from the junctions.
    • Peel the tape off the wire near the bottom of the case.
  4. MaxWest TAB-7360DC Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the two 4mm screws (circled in orange) with a 00 Phillips head driver.
    • Unclip the black plastic retainer near the data port. The PCB should now be able to be gently pulled off.
  5. MaxWest TAB-7360DC Motherboard Replacement: adım 5, 1 resimden 1.
    • Make contact with the battery terminals with the hot tip of the soldering iron for a few seconds while slowly pulling the wire away.
    • DO NOT TOUCH BOTH THE BLACK AND RED LEADS AT THE SAME TIME WITH THE SOLDERING IRON
  6. MaxWest TAB-7360DC Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. MaxWest TAB-7360DC Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • With the tweezers, grab onto the gray part of the ribbon clamps and pull away from the ribbons.
    • Once the ribbons are unclamped, they are able to slide out.
Sonuç
Clint Crabb
115 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S4-G3, Baechle Spring 2018 IUPUI, Team S4-G3, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S4G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 238
