Ana içeriğe geç
Mayflash Arcade Stick F300 Microswitch Replacement
Neye ihtiyacın var
  1. Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: adım 1, 3 resimden 1. Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: adım 1, 3 resimden 2. Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: adım 1, 3 resimden 3.
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
    FixBot'a Sor
    Yorum Ekle
  2. Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: adım 2, 2 resimden 1. Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: adım 2, 2 resimden 2.
    • Remove the four 9 mm truss head screws fastening the clear plastic square joystick gate to the casing underneath using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Mayflash Arcade Stick F300 Microswitch Replacement: adım 3, 3 resimden 1. Mayflash Arcade Stick F300 Microswitch Replacement: adım 3, 3 resimden 2. Mayflash Arcade Stick F300 Microswitch Replacement: adım 3, 3 resimden 3.
    • Gently push back on each of the four black locking tabs securing the joystick gate to the casing.
    • Remove the joystick gate.
    FixBot'a Sor
    Yorum Ekle
  4. Mayflash Arcade Stick F300 Microswitch Replacement: adım 4, 2 resimden 1. Mayflash Arcade Stick F300 Microswitch Replacement: adım 4, 2 resimden 2.
    • Lift the chosen microswitch vertically off the rod holding it in position.
    • Desolder the wire from the terminal (metal connection point).
    • Beware of overheating the soldering kit as it can damage electronic components.
    • Use a wire stripper or small blade to strip the insulation approximately 1 cm from the end of the wire before resoldering to the new part.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Saul Aguiar
293 İtibar
2 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-4, Crenshaw Fall 2024 Utah Tech University, Team 1-4, Crenshaw Fall 2024 üyesi
UTAHTECH-CRENSHAW-F24S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 57
Her zaman: 511
