Ana içeriğe geç
Mayflash Arcade Stick F300 USB Cable Replacement
Neye ihtiyacın var
  1. Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: adım 1, 3 resimden 1. Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: adım 1, 3 resimden 2. Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: adım 1, 3 resimden 3.
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
    FixBot'a Sor
    Yorum Ekle
  2. Mayflash Arcade Stick F300 USB Cable Replacement, USB Cable: adım 2, 2 resimden 1. Mayflash Arcade Stick F300 USB Cable Replacement, USB Cable: adım 2, 2 resimden 2.
    • Remove the four 10 mm truss head screws securing the PCB to the plastic outer casing using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Mayflash Arcade Stick F300 USB Cable Replacement: adım 3, 3 resimden 1. Mayflash Arcade Stick F300 USB Cable Replacement: adım 3, 3 resimden 2. Mayflash Arcade Stick F300 USB Cable Replacement: adım 3, 3 resimden 3.
    • Use a hair dryer or heat gun to soften the glue holding the USB cable into the socket on the PCB.
    • It should take less than a minute for the glue to be soft enough to remove. Do not overheat the circuit board.
    • Use a metal spudger to gently remove the softened glue.
    • Remove the cable from the socket
    FixBot'a Sor
    Yorum Ekle
  4. Mayflash Arcade Stick F300 USB Cable Replacement: adım 4, 3 resimden 1. Mayflash Arcade Stick F300 USB Cable Replacement: adım 4, 3 resimden 2. Mayflash Arcade Stick F300 USB Cable Replacement: adım 4, 3 resimden 3.
    • Slide the strain relief segment of the USB cable out of the plastic outer casing.
    • Remove the cable.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jess Anderson
342 İtibar
3 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-4, Crenshaw Fall 2024 Utah Tech University, Team 1-4, Crenshaw Fall 2024 üyesi
UTAHTECH-CRENSHAW-F24S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 40
Her zaman: 571
