Ana içeriğe geç
Maylong M-270 Motherboard Replacement
Neye ihtiyacın var
  1. Maylong M-270 Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Maylong M-270 Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Use the plastic opening tool to separate the back cover plate from the front.
    • Insert the plastic opening tool in between the back plate cover and the top cover, then slide along edges to pry open.
  2. Maylong M-270 Motherboard Replacement: adım 2, 2 resimden 1. Maylong M-270 Motherboard Replacement: adım 2, 2 resimden 2.
    • Locate the two ribbons attached to the device's motherboard.
    • Flip the small black plastic catches down by using the small end of the spudger.
    • Remove the ribbons by gently pulling them away from the motherboard.
  3. Maylong M-270 Motherboard Replacement: adım 3, 2 resimden 1. Maylong M-270 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the two screws from the motherboard.
    • Remove the four screws and metal holds from the edge of the device.
  4. Maylong M-270 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the motherboard by gently pulling it away from the bottom of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adam Sanders
222 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 550
