Ana içeriğe geç
Maylong MN-1000P Battery Replacement
Neye ihtiyacın var
  1. Maylong MN-1000P Battery Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Place the netbook top down, with the opening of the netbook facing you.
    FixBot'a Sor
    Yorum Ekle
  2. Maylong MN-1000P Battery Replacement: adım 2, 1 resimden 1.
    • Remove the six 6mm Phillips #00 screws from the netbook.
    FixBot'a Sor
    Yorum Ekle
  3. Maylong MN-1000P Battery Replacement: adım 3, 3 resimden 1. Maylong MN-1000P Battery Replacement: adım 3, 3 resimden 2. Maylong MN-1000P Battery Replacement: adım 3, 3 resimden 3.
    • Remove the sticker in the middle of the netbook.
    • Remove the middle 6mm Phillips #00 screw.
    FixBot'a Sor
    Yorum Ekle
  4. Maylong MN-1000P Battery Replacement: adım 4, 1 resimden 1.
    • Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
    FixBot'a Sor
    Yorum Ekle
  5. Maylong MN-1000P Battery Replacement: adım 5, 1 resimden 1.
    • Remove the bottom of the netbook by lifting the corners.
    FixBot'a Sor
    Yorum Ekle
  6. Maylong MN-1000P Battery Replacement, Battery: adım 6, 2 resimden 1. Maylong MN-1000P Battery Replacement, Battery: adım 6, 2 resimden 2.
    • Pinch the red and black wires connected to the section closest to the small white connector, and pull to remove them from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
katelyn buckman
553 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 31
Her zaman: 446
