Ana içeriğe geç
Maylong MN-1000P Screen Replacement
Neye ihtiyacın var
  1. Maylong MN-1000P Screen Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Place the netbook top down, with the opening of the netbook facing you.
    FixBot'a Sor
    Yorum Ekle
  2. Maylong MN-1000P Screen Replacement: adım 2, 1 resimden 1.
    • Remove the six 6mm Phillips #00 screws from the netbook.
    FixBot'a Sor
    Yorum Ekle
  3. Maylong MN-1000P Screen Replacement: adım 3, 3 resimden 1. Maylong MN-1000P Screen Replacement: adım 3, 3 resimden 2. Maylong MN-1000P Screen Replacement: adım 3, 3 resimden 3.
    • Remove the sticker in the middle of the netbook.
    • Remove the middle 6mm Phillips #00 screw.
    FixBot'a Sor
    Yorum Ekle
  4. Maylong MN-1000P Screen Replacement: adım 4, 1 resimden 1.
    • Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
    FixBot'a Sor
    Yorum Ekle
  5. Maylong MN-1000P Screen Replacement: adım 5, 1 resimden 1.
    • Remove the bottom of the netbook by lifting the corners.
    FixBot'a Sor
    Yorum Ekle
  6. Maylong MN-1000P Screen Replacement, Battery: adım 6, 2 resimden 1. Maylong MN-1000P Screen Replacement, Battery: adım 6, 2 resimden 2.
    • Pinch the red and black wires connected to the section closest to the small white connector, and pull to remove them from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Maylong MN-1000P Screen Replacement, Screen: adım 7, 1 resimden 1.
    • Remove the six 6mm Phillips #00 screws from both sides of the netbook.
    FixBot'a Sor
    Yorum Ekle
  8. Maylong MN-1000P Screen Replacement: adım 8, 2 resimden 1. Maylong MN-1000P Screen Replacement: adım 8, 2 resimden 2.
    • Pull the top of the computer and the back side of the computer away from each other until they are detached.
    • Flip the entire computer over so you can see both the screen and keyboard.
    FixBot'a Sor
    Yorum Ekle
  9. Maylong MN-1000P Screen Replacement: adım 9, 2 resimden 1. Maylong MN-1000P Screen Replacement: adım 9, 2 resimden 2.
    • Remove all the black circular pads from around the screen.
    • Remove all 6mm Phillips #00 screws from around the screen bezel.
    FixBot'a Sor
    Yorum Ekle
  10. Maylong MN-1000P Screen Replacement: adım 10, 1 resimden 1.
    • Using a plastic opening tool, pry off the screen bezel.
    • After detaching the screen bezel, pull up on the bezel near the hinge area.
    FixBot'a Sor
    Yorum Ekle
  11. Maylong MN-1000P Screen Replacement: adım 11, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to gently pull on the black and white wires at the top of the netbook until the white connector detaches.
    FixBot'a Sor
    Yorum Ekle
  12. Maylong MN-1000P Screen Replacement: adım 12, 1 resimden 1.
    • Use your fingers to pull on the green, red, black, and white intertwined wires at the bottom of the netbook until the white connector detaches.
    FixBot'a Sor
    Yorum Ekle
  13. Maylong MN-1000P Screen Replacement: adım 13, 3 resimden 1. Maylong MN-1000P Screen Replacement: adım 13, 3 resimden 2. Maylong MN-1000P Screen Replacement: adım 13, 3 resimden 3.
    • Detach the wide yellow ribbon cable connected to the screen from the computer.
    FixBot'a Sor
    Yorum Ekle
  14. Maylong MN-1000P Screen Replacement: adım 14, 2 resimden 1. Maylong MN-1000P Screen Replacement: adım 14, 2 resimden 2.
    • Flip the computer over.
    • Disconnect the red, green, black, and white intertwined wires from the connector to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  15. Maylong MN-1000P Screen Replacement: adım 15, 3 resimden 1. Maylong MN-1000P Screen Replacement: adım 15, 3 resimden 2. Maylong MN-1000P Screen Replacement: adım 15, 3 resimden 3.
    • Remove the black tape holding down the red, green, black, and white intertwined wires.
    • Remove the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
katelyn buckman
553 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 370
