Ana içeriğe geç
Maytag Bravos Drive Belt Replacement
Neye ihtiyacın var
  1. Maytag Bravos Drive Belt Replacement, Drive Belt: adım 1, 1 resimden 1.
    • Disconnect the power supply from your Maytag Bravos washer. Following this, pull the device approximately 2 feet away from the wall.
  2. Maytag Bravos Drive Belt Replacement: adım 2, 2 resimden 1. Maytag Bravos Drive Belt Replacement: adım 2, 2 resimden 2.
    • This step may be easier with two people.
    • Gently rest the washing machine against a wall or hard surface to keep it slightly elevated. This is important as you will need access to the underside of the machine for the following step.
  3. Maytag Bravos Drive Belt Replacement: adım 3, 1 resimden 1.
    • Have your 1/4-inch drive ratchet ready for the following step.
  4. Maytag Bravos Drive Belt Replacement: adım 4, 2 resimden 1. Maytag Bravos Drive Belt Replacement: adım 4, 2 resimden 2.
    • Have someone carefully watch over the washing machine and make sure it is firmly rested against the wall to prevent injury.
    • Under the washing machine you will see a plastic cover over the drive belt. To remove this use your 1/4" drive ratchet.
  5. Maytag Bravos Drive Belt Replacement: adım 5, 1 resimden 1.
    • Following the removal of the cover, place the bolts inside the cover and place to the side somewhere safe.
  6. Maytag Bravos Drive Belt Replacement: adım 6, 1 resimden 1.
    • Following removal of the cover you will see the drive belt roped around two cogs.
    • The belt is fairly elastic and easy to remove. Remove the drive belt gently and replace with the new belt.
  7. Maytag Bravos Drive Belt Replacement: adım 7, 1 resimden 1.
    • Reattach the drive belt cover using your 1/4" drive ratchet.
  8. Maytag Bravos Drive Belt Replacement: adım 8, 2 resimden 1. Maytag Bravos Drive Belt Replacement: adım 8, 2 resimden 2.
    • Gently rest the washing machine back against the wall and reconnect all power supply.
Sonuç
To replace your drive belt in your Maytag Bravos washer follow this simple 8 step guide.
3 farklı kişi bu kılavuzu tamamladı.
Reilly Farr
259 İtibar
1 Kılavuz yazıldı
2 Yorum
What’s the trick of getting the new belt on the wheels?
palmer910 - Yanıt
Where can I find a drive belt for a Maytag Bravos MVWB750WQ0??? I have looked and looked online, and cannot find a source!
J Lipson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 46
Son 30 gün: 245
Her zaman: 17,566
