Ana içeriğe geç
Maytag MVWX655DW1 Washer Basket Hub Replacement
Neye ihtiyacın var
  1. Maytag MVWX655DW1 Washer Basket Hub Replacement, Washer Basket Hub: adım 1, 1 resimden 1.
    • Use a 1/4-in Flathead screwdriver to remove the three 5mm screws behind the washing machine.
  2. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 2, 3 resimden 1. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 2, 3 resimden 2. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 2, 3 resimden 3.
    • Tape the lid down so it does not open when removing.
    • Pull the lid forward with your thumbs while pushing against the washer with your fingers.
    • Lift the lid up and place on the slots located where you removed the screws from the back.
  3. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 3, 3 resimden 1. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 3, 3 resimden 2. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 3, 3 resimden 3.
    • Remove the cap from the agitator with your flat head screwdriver. It should pop right off.
    • Using your 7/16 socket, unscrew the bolt attaching the agitator to the motor shaft.
  4. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 4, 3 resimden 1. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 4, 3 resimden 2. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 4, 3 resimden 3.
    • Lift up on the agitator and it should slide off the motor shaft exposing the washer hub underneath.
    • If it is stuck, put bolt back in halfway. Tap the bolt with a hammer while pulling up on the agitator to jog it loose.
  5. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 5, 3 resimden 1. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 5, 3 resimden 2. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 5, 3 resimden 3.
    • Use your Phillips #3 screwdriver to pull the retaining slip out.
    • Unscrew the six screws with the same Phillips #3 screwdriver to remove the hub.
  6. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 6, 2 resimden 1. Maytag MVWX655DW1 Washer Basket Hub Replacement: adım 6, 2 resimden 2.
    • Take the new hub and slide it over the motor shaft.
    • Align the holes by only slightly screwing in each screw and turning the hub until all holes are aligned and screws are in.
    • Tighten all screws and then put new retaining clip into hub.
Sonuç
Kyle
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 44
Son 30 gün: 173
Her zaman: 8,333
