Giriş
A common fault with the Arete One is for the display to stop working but showing nonsense symbols or in some cases not showing anything at all, but still responding to button presses with beeps. This seems to be caused by the two digit display component which is a very cheap component.
This issue can be diagnosed by the device not performing any of the normal functions of air purification or dehumidification, and the buttons do appear to cause beeps and changes on the display but the normal modes of operation don't cycle while pressing the buttons.
In my case, the device would beep when power was supplied, with a blank display. If I pressed the power button then as long as I held it, the display would show "L!".
I think this was a red herring as there wasn't a particular device fault code in the manual corresponding to that.
Looking at this reddit thread, there are many people experiencing issues relating to the display.
Here's my sources for how I figured this guide out: thanks to these people!
Neye ihtiyacın var
Videoya Genel Bakış
4x in the vent
4x after removing the water tank (2 at the top and 2 at the bottom (bottom screws not pictured)
It's difficult to remove but you just have to pull it. This video is handy to see the full dismantle process: https://youtu.be/Oc8chhGgatQ
Approx 6-8 screws to remove. Objective is to be able to partially pull off white cover on the other side and lift off display cover from top.
Depending on which size of unit you have, you may have a plastic clip or a screw here. The clip is difficult to unclip, but a flathead screwdriver can be used to push it in, hard, with one hand while lifting the display cover up with the other
Detach the two connectors by squeezing the clamps and pulling them off.
The whole top of the unit should now be completely detached
Unscrew the two Phillips screws holding the circuit board to the cover
Carefully unclip the circuit board
The highlighted 10 pins hold the display on
Once you've desoldered the pins, use a pair of pliers to grip the 2 digit display and pull it off the circuit board
If you connect the circuit board carefully and try to only touch the power button you can see if the device works - it should be working without a screen.
There are many replacement screens available. You need to find a common cathode two digit (sometimes called two bit) 7 segment 0.4 inch display with white LEDs (LED colour is probably not important)
0.4 inches refers to the short edge of the display
I found this one: https://www.aliexpress.com/item/10050085...
Which is ~£1 for 5 of them
Make sure it's got 10 pins - 5 on each side
