Ana içeriğe geç
Mechanical Pencil Spring Replacement
Neye ihtiyacın var
  1. Mechanical Pencil Spring Replacement, Spring: adım 1, 2 resimden 1. Mechanical Pencil Spring Replacement, Spring: adım 1, 2 resimden 2.
    • Remove the eraser from the mechanical pencil.
    • Removing the eraser may be difficult if the eraser is too short.
  2. Mechanical Pencil Spring Replacement: adım 2, 1 resimden 1.
    • Remove the graphite lead from the pencil.
    • Make sure to give the pencil a few clicks to get any remaining lead out of the front of the pencil.
  3. Mechanical Pencil Spring Replacement: adım 3, 2 resimden 1. Mechanical Pencil Spring Replacement: adım 3, 2 resimden 2.
    • Unscrew the cone/cap from the pencil.
    • You may be able to unscrew the cap. Some require you to pull it off using force. Procedures vary based on each pencil.
  4. Mechanical Pencil Spring Replacement: adım 4, 2 resimden 1. Mechanical Pencil Spring Replacement: adım 4, 2 resimden 2.
    • Depress the shaft into the sleeve.
  5. Mechanical Pencil Spring Replacement: adım 5, 3 resimden 1. Mechanical Pencil Spring Replacement: adım 5, 3 resimden 2. Mechanical Pencil Spring Replacement: adım 5, 3 resimden 3.
    • While keeping the shaft depressed, slide the gold dispenser ring back into the sleeve to expose the dispenser.
  6. Mechanical Pencil Spring Replacement: adım 6, 3 resimden 1. Mechanical Pencil Spring Replacement: adım 6, 3 resimden 2. Mechanical Pencil Spring Replacement: adım 6, 3 resimden 3.
    • Use pliers to grasp the dispenser perpendicular to the open split.
    • Apply pressure and pull the dispenser straight out from the shaft and sleeve. This may be difficult.
    • If the dispenser is grasped incorrectly it could cause damage.
    • Be careful not to lose or bend the dispenser ring in the process. It is small and fragile.
  7. Mechanical Pencil Spring Replacement: adım 7, 1 resimden 1.
    • Remove the shaft and spring from the sleeve.
    • The spring is small. Be sure not to lose it so it can be discarded properly.
  8. Mechanical Pencil Spring Replacement: adım 8, 2 resimden 1. Mechanical Pencil Spring Replacement: adım 8, 2 resimden 2.
    • Place the dispenser and dispenser ring into the sleeve in the order it was removed.
    • The flange or widest portion of the dispenser ring will be closest to the opening of the dispenser.
    • You will need to hold it in place for the next step.
  9. Mechanical Pencil Spring Replacement: adım 9, 2 resimden 1. Mechanical Pencil Spring Replacement: adım 9, 2 resimden 2.
    • Place the new spring and old shaft into the sleeve in the order it was taken out.
    • The spring is small. Be sure not to lose it.
  10. Mechanical Pencil Spring Replacement: adım 10, 3 resimden 1. Mechanical Pencil Spring Replacement: adım 10, 3 resimden 2. Mechanical Pencil Spring Replacement: adım 10, 3 resimden 3.
    • Using your thumb or a hard surface pressed against the dispenser, push the shaft into the dispenser.
    • There should be an audible clicking sound.
    • Pushing the dispenser into the shaft from the front could cause damage to dispenser and dispenser ring.
Sonuç
To reassemble your device, follow steps 1 - 3 of these instructions in reverse order.
4 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 48
Son 30 gün: 163
Her zaman: 10,189
