Ana içeriğe geç
Meepo Mini 5 Truck Bushing Replacement
Neye ihtiyacın var
  1. Meepo Mini 5 Truck Bushing Replacement, Truck Bushing: adım 1, 2 resimden 1. Meepo Mini 5 Truck Bushing Replacement, Truck Bushing: adım 1, 2 resimden 2.
    • Rotate the half-inch wrench counter-clockwise to loosen the bushing bolt.
  2. Meepo Mini 5 Truck Bushing Replacement: adım 2, 2 resimden 1. Meepo Mini 5 Truck Bushing Replacement: adım 2, 2 resimden 2.
    • Take out the truck bushing (orange part).
  3. Meepo Mini 5 Truck Bushing Replacement: adım 3, 1 resimden 1.
    • Take the wheels out of the screw by pulling it toward you.
  4. Meepo Mini 5 Truck Bushing Replacement: adım 4, 1 resimden 1.
    • Remove the washer from the top of the bushing.
  5. Meepo Mini 5 Truck Bushing Replacement: adım 5, 1 resimden 1.
    • Take out the bottom bushing (orange part).
  6. Meepo Mini 5 Truck Bushing Replacement: adım 6, 1 resimden 1.
    • Take off the metal cap from the bushing.
  7. Meepo Mini 5 Truck Bushing Replacement: adım 7, 1 resimden 1.
    • Replace with the new bushing to the cap.
  8. Meepo Mini 5 Truck Bushing Replacement: adım 8, 1 resimden 1.
    • Press the bushing back.
  9. Meepo Mini 5 Truck Bushing Replacement: adım 9, 2 resimden 1. Meepo Mini 5 Truck Bushing Replacement: adım 9, 2 resimden 2.
    • Press the hanger back (wheels)
    • Press the wire and point the semicircular ridge to the hole at the same time as the space is narrow.
  10. Meepo Mini 5 Truck Bushing Replacement: adım 10, 1 resimden 1.
    • Press the upper bushing and the cap back on.
  11. Meepo Mini 5 Truck Bushing Replacement: adım 11, 1 resimden 1.
    • Press the pin back on.
  12. Meepo Mini 5 Truck Bushing Replacement: adım 12, 1 resimden 1.
    • Rotate the 1/2 inch wrench clockwise to tighten the pin.
Sonuç
Richard
205 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 3-1, Whithaus Spring 2024 UC Davis, Team 3-1, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S3G1
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 69
