Giriş
Screen replacement (without frame)
Neye ihtiyacın var
Remove the back panel, and unscrew everything to remove the second back panel. Some screw are longer than other. But I mixed them without issue. Here I saw the solution for the network issue: the little contacts between motherboard and screen were bended.
I removed the battery, but I think it's not mandatory. If you do, be careful, it's very well glued, and there is some wires behind.
5 farklı kişi bu kılavuzu tamamladı.
