Remove the hose connecting the upper piston and the coffee outlet.
Remove the upper piston.
Remove the Torx T20 screw from the screen of the upper piston.
Take off the cover of the gasket and the gasket.
Replace the gaskets of the upper piston, the coffee outlet and water connector.
Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
Work through the steps in reverse order to reassemble your device.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
