Ana içeriğe geç
Memorex CD Alarm Clock Radio PCB Board Replacement
Neye ihtiyacın var
  1. Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: adım 1, 3 resimden 1. Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: adım 1, 3 resimden 2. Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: adım 1, 3 resimden 3.
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio PCB Board Replacement: adım 2, 3 resimden 1. Memorex CD Alarm Clock Radio PCB Board Replacement: adım 2, 3 resimden 2. Memorex CD Alarm Clock Radio PCB Board Replacement: adım 2, 3 resimden 3.
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio PCB Board Replacement, PCB Board: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the (5) 7mm screws with a Phillips #1 screwdriver and a pair of tweezers.
    • Using a magnetic tip screwdriver will prevent screw loss.
  4. Memorex CD Alarm Clock Radio PCB Board Replacement: adım 4, 3 resimden 1. Memorex CD Alarm Clock Radio PCB Board Replacement: adım 4, 3 resimden 2. Memorex CD Alarm Clock Radio PCB Board Replacement: adım 4, 3 resimden 3.
    • Locate the wiring harness.
    • Disconnect the wiring harness using the tweezers.
  5. Memorex CD Alarm Clock Radio PCB Board Replacement: adım 5, 1 resimden 1.
    • Remove the PCB board from the device.
    • Replace the broken motherboard with a new PCB board.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 14
Her zaman: 381
