Ana içeriğe geç
Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement
Neye ihtiyacın var
  1. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement, Tail/Reverse/Rear Turn Signal Bulb: adım 1, 1 resimden 1.
    • The access panel for all of these lights is on the inside of the trunk. There's one on each side. This guide will cover one side; simply repeat on the other to complete the job.
  2. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: adım 2, 1 resimden 1.
    • The panel is secured with two thumb screws. Remove these.
  3. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: adım 3, 1 resimden 1.
    • Pull the panel out and away from the back of the car, being careful not to force the bulbs out of the holes.
  4. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: adım 4, 1 resimden 1.
    • There are five bulbs in each tail light housing. They are as follows:
    • Brake light
    • Reverse light
    • Tail light
    • Turn signal
    • Side marker
  5. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: adım 5, 1 resimden 1.
    • To remove any of the bulbs simply turn them counter clockwise approximately a half turn and then pull them out of their socket.
  6. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: adım 6, 3 resimden 1. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: adım 6, 3 resimden 2. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: adım 6, 3 resimden 3.
    • Three of the bulbs are #1156
    • One is a #96
    • One is a small 4W blub
  7. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: adım 7, 1 resimden 1.
    • Before installing the new bulb consider cleaning the socket with a soft metal wire brush such as the brass brush shown to help remove any corrosion.
    • Then install the new bulb, reassemble the device, and finally, be sure to test that all of your rear lights are working before going for a drive.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Nicolas Siemsen
39.040 İtibar
79 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.535 adet Kılavuz yazıldı
2 Yorum
Very informative, descriptive and point on analysis.
George T Peeke - Yanıt
Und wie wird dies beim Kombi gemacht?
srossius - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 87
Her zaman: 12,284
