Giriş
How to remove the plastic steps from the baseboards of doors in an easy way
Door Sill remove
The steps are the same for the 4 doors and the pieces are under pressure. Likewise, time can cause them to get stuck, you must proceed with care.
First we will have to open the door, and locate one of the corners, in which a plastic tool is inserted, with which we will travel the length of the piece to release it, this without forcing the piece.
Once the previous step is done, introduce a second plastic tool (it can be a screwdriver covered with tape) on the inside of the piece, it must be inserted as close to the center of it, this is the side where we will exert leverage to release the piece. of its fit.
Firmly exert force, but without violence, making sure the piece does not flex too much, remember that it is old plastic. If necessary, pry both tools, making sure they are as far inside as possible.
You can use your hands once you have managed to lift one of the sides.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
HelloMacOS dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
