Ana içeriğe geç
Mercedes W123 Fuel Lines (Rear) Replacement
Neye ihtiyacın var
  1. Mercedes W123 Fuel Lines (Rear) Replacement, Fuel Lines, Rear: adım 1, 2 resimden 1. Mercedes W123 Fuel Lines (Rear) Replacement, Fuel Lines, Rear: adım 1, 2 resimden 2.
    • Before replacing any of the lines at the rear of the car the fuel tank must be drained of any fuel. It is obviously best to perform this work when the fuel tank is near empty to avoid having to store too much fuel during the rest of the job.
    • The tank is most easily drained from the main fuel feed line which comes out of the bottom of the tank just above the rear passenger side axle.
    • It has a metal fitting on the top end that threads in to the tank screen.
    • The other end is rubber hose and clamps to the main metal feed line going towards the front of the car.
    • To limit fuel spillage when removing the clamped rubber end of the line, pinch the fuel hose between some vice grips as pictured.
  2. Mercedes W123 Fuel Lines (Rear) Replacement: adım 2, 1 resimden 1.
    • Position your catch container near the main fuel feed line. Using a container that you can insert a long funnel in will be helpful. It should be large enough to hold the amount of fuel you estimate to be in the tank. Or, you should have multiple containers on hand.
  3. Mercedes W123 Fuel Lines (Rear) Replacement: adım 3, 2 resimden 1. Mercedes W123 Fuel Lines (Rear) Replacement: adım 3, 2 resimden 2.
    • Next, unscrew the hose clamp at the rubber end of the main fuel feed line. This usually takes a Phillips or flathead screwdriver.
    • Then pull that end of hose off the metal fuel line (fuel should not flow out thanks to the vice grip pinching the line). Aim the hose at your catch container/funnel. Then remove the vice grip and let the fuel flow in to the container.
  4. Mercedes W123 Fuel Lines (Rear) Replacement: adım 4, 1 resimden 1.
    • Once the tank is fully drained you will need to use a 19mm wrench to remove the main fuel feed line from the tank.
  5. Mercedes W123 Fuel Lines (Rear) Replacement: adım 5, 1 resimden 1.
    • You will be left with an opening in the bottom of the tank. This will likely slowly drip for some time. Leave a catch pan underneath or place some shop towels or rags underneath to catch the drips.
  6. Mercedes W123 Fuel Lines (Rear) Replacement: adım 6, 1 resimden 1.
    • Next, you'll remove the two short lengths of fuel hose for the tank return lines.
    • If the clamps look as rusty as these, consider spraying them with some penetrating lubricant before removing them.
  7. Mercedes W123 Fuel Lines (Rear) Replacement: adım 7, 1 resimden 1.
    • Loosen all four of the hose clamps on both fuel lines using a Phillips or flathead screwdriver as needed.
  8. Mercedes W123 Fuel Lines (Rear) Replacement: adım 8, 1 resimden 1.
    • With all four clamps loosened, pull both lines off. You can see here what the metal fuel lines look like with the lines removed.
  9. Mercedes W123 Fuel Lines (Rear) Replacement: adım 9, 1 resimden 1.
    • Now it is time to proceed with installation of the new lines. Installation is generally the reverse of removal. However, following are some helpful tips.
    • Start with the main fuel feed line. It has a metal fitting on one end that screws in to the tank. Screw this in, the opposite of removal.
    • The new line likely comes with excess rubber line. You should cut the hose short enough to avoid touching any other parts like the axles or differential, but long enough to make a graceful bend to the fuel line it attaches to. Use your best judgement, and start longer than you think. You can always make it shorter.
    • Then, clamp the rubber end to the metal fuel line. Use a new hose clamp, if available.
  10. Mercedes W123 Fuel Lines (Rear) Replacement: adım 10, 1 resimden 1.
    • Next, cut new lengths of hose to fit the rear return lines. Use the old hose as a guide for cutting your new lengths.
    • Push the fuel line over the metal hose ends with the clamps over the new line. Then tighten the clamps. Be mindful that the clamps don't touch the adjacent line at the risk of the clamp rubbing through the line over time.
  11. Mercedes W123 Fuel Lines (Rear) Replacement: adım 11, 1 resimden 1.
    • You can now proceed to refill your fuel tank with the fuel you drained.
Sonuç
When done, check for leaks. Go for a drive, and check for leaks again.
10 farklı kişi bu kılavuzu tamamladı.
Nicolas Siemsen
39.040 İtibar
79 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.535 adet Kılavuz yazıldı
4 Yorum
On my w123, the short rubber lines (fuel grade rubber) were 9mm inside diameter and the other one was standard 5/16" rubber fuel line. The tank screen came out with the other fuel line so I used a tiny brass brush and carefully cleaned it as well & re installed with the new hose as he shows in the guide. Guide was helpful, thanks!
Frank - Yanıt
Frank, glad to hear it was helpful!
Nicolas Siemsen -
How is called the metal part of the hose (the one attached to the tank) and its dimension and material ?
hjoab -
OEM fuel sending line (From tank filter to supply side) available from PelicanParts and other sources: https://www.pelicanparts.com/More_Info/1...
Joe Smith - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 37
Son 30 gün: 171
Her zaman: 21,688
