Ana içeriğe geç
Giriş
Only installed on a small portion of W123 cars, the over-voltage protection relay can be a bit of a mystery at first. In reality, however, it's quite simple.
While most or all of the electrical systems on all W123 cars are protected by metal fuses, these are designed to trip only with excess amperage. For example, the blue 25 amp fuse for the climate control system will only blow if the system draws over 25 amps due to a short or other problem.
However there were some new components added to the 1984 California model, and all 1985 models, of the W123 that needed protection from over-voltage as well. One example is the new computer that controls the EGR.
A the time, the best way Mercedes had to protect these items was with the over-voltage protection relay (the OVP relay). This setup allows a fuse to function as a voltage protector. It works by using a relay that monitors the voltage across the electrical system in the car. If the voltage exceeds a certain level, the relay shorts itself internally, which draws an excess amperage on the integral 10 amp fuse on top of the relay. This blows the fuse, cutting of current to the sensitive systems.
One of the easiest to recognize symptoms of a blown OVP fuse or bad OVP relay is that the tachometer will not function. In addition, the A/C compressor will not engage.
First try replacing the fuse to see if the blown fuse was a fluke. If the new fuse does not fix it or blows again quickly, you may need to replace the relay. This guide covers both.
  1. Mercedes W123 Over-voltage Protection Relay and Fuse Replacement, Over-voltage Protection Relay and Fuse: adım 1, 1 resimden 1.
  2. Mercedes W123 Over-voltage Protection Relay and Fuse Replacement: adım 2, 1 resimden 1.
    • Look up inside below the dash, just beneath the furthest right side dash vent. You'll see the OVP relay with the red ruse on top.
    • Even if you are just checking the fuse, the easiest way to get access is to remove the entire relay. Simply pull it up and off of the black plug it is attached to, which sits beneath it.
  3. Mercedes W123 Over-voltage Protection Relay and Fuse Replacement: adım 3, 1 resimden 1.
    • This is the OVP relay out from under the dash.
    • The fuse on top slides in side-ways. It is a 10 amp fuse.
    • You can use a needle nose pliers to pull the fuse out of the holder that is attached to the relay.
  4. Mercedes W123 Over-voltage Protection Relay and Fuse Replacement: adım 4, 1 resimden 1.
    • As you can see here, the fuse was blown. The filament is broken internally.
    • Since this was the case, the fuse was replaced. The tachometer returned to normal function indicating that the fuse was the problem.
    • If the fuse continues to blow, the OVP relay may need to be replaced. If the fuse is not blow, you may need to test and/or replace the OVP relay.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Nicolas Siemsen
37.918 İtibar
79 adet Kılavuz yazıldı
Master Techs Master Techs üyesi
Community
308 Üyeler
1.131 adet Kılavuz yazıldı
2 Comments
Hi,
Thanks for the tutorial, does this apply to 1986 560sl?
Thanks,
Patrick
pepe - Yanıt
Hi guys just want to know what amp's are the 2 fuses
By the relay under the hood..thanks in advance
Charles Lottering - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 63
Son 30 gün: 311
Her zaman: 23,971
