Ana içeriğe geç
Merch Source Projector Entertainment II Light Bulb Replacement
Neye ihtiyacın var
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: adım 1, 2 resimden 1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: adım 1, 2 resimden 2.
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      FixBot'a Sor
      Yorum Ekle
    2. Merch Source Projector Entertainment II Light Bulb Replacement: adım 2, 1 resimden 1.
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      FixBot'a Sor
      Yorum Ekle
    3. Merch Source Projector Entertainment II Light Bulb Replacement: adım 3, 2 resimden 1. Merch Source Projector Entertainment II Light Bulb Replacement: adım 3, 2 resimden 2.
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      FixBot'a Sor
      Yorum Ekle
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: adım 4, 3 resimden 1. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: adım 4, 3 resimden 2. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: adım 4, 3 resimden 3.
      • Remove the light bulb from its housing unit.
      • Do not damage the 2 white cables leading into the light bulb panel.
      FixBot'a Sor
      Yorum Ekle
    2. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: adım 5, 2 resimden 1. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: adım 5, 2 resimden 2.
      • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
      • The light blub is held into the socket with prongs, and should easily pull straight out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephanie
282 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-3, Maness Winter 2015 Cal Poly, Team 18-3, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G3
3 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 2,648
