Ana içeriğe geç
MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement
Neye ihtiyacın var
  1. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement, Battery Contacts in Remote Controller: adım 1, 2 resimden 1. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement, Battery Contacts in Remote Controller: adım 1, 2 resimden 2.
    • Turn the remote controller over to the back.
  2. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: adım 2, 1 resimden 1.
    • Slide the battery cover off in the direction of the arrow on the cover.
  3. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: adım 3, 2 resimden 1. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: adım 3, 2 resimden 2.
    • Remove the batteries (2 AA).
  4. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: adım 4, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the four screws located in the four corners of the back of the remote controller.
    • Screw length is 6 mm.
  5. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: adım 5, 2 resimden 1. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: adım 5, 2 resimden 2.
    • Separate the two halves of the remote controller.
  6. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: adım 6, 2 resimden 1. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: adım 6, 2 resimden 2.
    • Lift the metal tab until it is straight and can move through the slot in the battery compartment.
  7. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: adım 7, 2 resimden 1. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: adım 7, 2 resimden 2.
    • Flip the remote controller to the external side and slide the metal connections in the battery compartment straight up.
    • Slide the new connections straight down into the slot in the battery compartment, flip to the internal side, and bend the metal tab until it's parallel with the battery compartment.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 203
