Giriş
This repair guide will show you how to replace the gaskets in the MerchSource the Black Series Boat Racers toy boat. The gaskets are foam pieces that secure the battery compartment in the boat from water leakage.
  1. Remove the screw on the top of the boat at the rear end using a Phillips #2 screwdriver. Screw length is 16 mm.
    • Remove the screw on the top of the boat at the rear end using a Phillips #2 screwdriver.
    • Screw length is 16 mm.
  2. Remove the top of the boat by sliding it backwards and then pulling it off. Remove the top of the boat by sliding it backwards and then pulling it off. Remove the top of the boat by sliding it backwards and then pulling it off.
    • Remove the top of the boat by sliding it backwards and then pulling it off.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Grab the rubber gasket with tweezers and pull it out of the slot. Grab the rubber gasket with tweezers and pull it out of the slot.
    • Grab the rubber gasket with tweezers and pull it out of the slot.
  5. Gently remove the gasket and replace with a new one. Gently remove the gasket and replace with a new one. Gently remove the gasket and replace with a new one.
    • Gently remove the gasket and replace with a new one.
Sonuç
Monica Reece
651 İtibar
5 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 52
