Ana içeriğe geç
Meta Quest 2 Head Strap Replacement
  1. Meta Quest 2 Head Strap Replacement, Remove the facial interface: adım 1, 2 resimden 1. Meta Quest 2 Head Strap Replacement, Remove the facial interface: adım 1, 2 resimden 2.
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
    FixBot'a Sor
    Yorum Ekle
  2. Meta Quest 2 Head Strap Replacement: adım 2, 2 resimden 1. Meta Quest 2 Head Strap Replacement: adım 2, 2 resimden 2.
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
    FixBot'a Sor
    Yorum Ekle
  3. Meta Quest 2 Head Strap Replacement: adım 3, 1 resimden 1.
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
    FixBot'a Sor
    Yorum Ekle
  4. Meta Quest 2 Head Strap Replacement, Unclip the side straps: adım 4, 3 resimden 1. Meta Quest 2 Head Strap Replacement, Unclip the side straps: adım 4, 3 resimden 2. Meta Quest 2 Head Strap Replacement, Unclip the side straps: adım 4, 3 resimden 3.
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
    FixBot'a Sor
    Yorum Ekle
  5. Meta Quest 2 Head Strap Replacement: adım 5, 2 resimden 1. Meta Quest 2 Head Strap Replacement: adım 5, 2 resimden 2.
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
    FixBot'a Sor
    Yorum Ekle
  6. Meta Quest 2 Head Strap Replacement, Remove the top strap: adım 6, 2 resimden 1. Meta Quest 2 Head Strap Replacement, Remove the top strap: adım 6, 2 resimden 2.
    • Separate the hook and loop strip on the top strap.
    FixBot'a Sor
    Yorum Ekle
  7. Meta Quest 2 Head Strap Replacement, Remove the head strap: adım 7, 2 resimden 1. Meta Quest 2 Head Strap Replacement, Remove the head strap: adım 7, 2 resimden 2.
    • Unthread the top strap from its bracket.
    • Remove the head strap.
    FixBot'a Sor
    Yorum Ekle
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
343.688 İtibar
915 adet Kılavuz yazıldı
1Rehber Yorum
Merci pour ce tuto qui m'a permis de nettoyer la sangle. En revanche comme elle s'est décollée de ses deux supports, il a fallu la recoller.
Max Grammare - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 22
Son 7 gün: 150
Son 30 gün: 760
Her zaman: 48,512
