Ana içeriğe geç
Meta Quest 2 Head Strap Replacement
  1. Meta Quest 2 Head Strap Replacement, Remove the facial interface: adım 1, 2 resimden 1. Meta Quest 2 Head Strap Replacement, Remove the facial interface: adım 1, 2 resimden 2.
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  2. Meta Quest 2 Head Strap Replacement: adım 2, 2 resimden 1. Meta Quest 2 Head Strap Replacement: adım 2, 2 resimden 2.
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Head Strap Replacement: adım 3, 1 resimden 1.
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  4. Meta Quest 2 Head Strap Replacement, Unclip the side straps: adım 4, 3 resimden 1. Meta Quest 2 Head Strap Replacement, Unclip the side straps: adım 4, 3 resimden 2. Meta Quest 2 Head Strap Replacement, Unclip the side straps: adım 4, 3 resimden 3.
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  5. Meta Quest 2 Head Strap Replacement: adım 5, 2 resimden 1. Meta Quest 2 Head Strap Replacement: adım 5, 2 resimden 2.
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  6. Meta Quest 2 Head Strap Replacement, Remove the top strap: adım 6, 2 resimden 1. Meta Quest 2 Head Strap Replacement, Remove the top strap: adım 6, 2 resimden 2.
    • Separate the hook and loop strip on the top strap.
  7. Meta Quest 2 Head Strap Replacement, Remove the head strap: adım 7, 2 resimden 1. Meta Quest 2 Head Strap Replacement, Remove the head strap: adım 7, 2 resimden 2.
    • Unthread the top strap from its bracket.
    • Remove the head strap.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
282.218 İtibar
585 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.446 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 153
Son 30 gün: 660
Her zaman: 36,470
